Beada 6.8 in weird issue
tuftybruno
Post by tuftybruno » Wed Nov 12, 2025 11:55 am
Hi... need some help with my Baada panel. In short, regardless how many times I reflash my panel, beada service tool senses my panel as a Model 5 instead of 6 but yet the resolution is noted properly. With that said, it leads to Win11 also detecting the panel as a Model 5 and subsequent software (AIDA, InfoPanel) get the Model 5 and its associate resolutions (which do not match my actual screen).
I attached some images that I hope help. Any assistance is very appreciated.
For reference, I have followed:
https://www.esky-sh.com/bbs/viewtopic.php?f=30&t=955
with files from:
https://onedrive.live.com/?redeem=aHR0c ... 633C899FB1
I have also manually tried to flash to older versions but none seems to change the symptom/problem
Let me know if there is any other information I can provide. Thank you in advance again.
Service Tool 1.png (22.03 KiB) Viewed 29504 times
Service Tool 2.png (11.32 KiB) Viewed 29504 times
Re: Beada 6.8 in weird issue
Post by esky-sh » Wed Nov 12, 2025 5:32 pm
This issue may caused by a partial upgrade/downgrade. Orders were mis-aligned during operation.
I suggest you to do a thoroughly downgrade.
When you are doing procedures in Section 4, please remember write pmf file to 2 ext4 partions on eMMC, instead of first ext4 partition which stated in guidance.
https://www.esky-sh.com/bbs/viewtopic.p ... t=10#p4121
tuftybruno
Post by tuftybruno » Thu Nov 13, 2025 9:58 am
Hi - thank you for the reply.
I had tried that prior because I had seen the same post you sent and I tried again just now to make sure to flash both partitions. Unfortunately, I have the same outcome. Beada Service Tool still sees as a Model 5 (but model 6 resolution). Any thoughts, is there a different process for the my model?
Thank you again in advance.
Post by esky-sh » Thu Nov 13, 2025 11:39 am
What is the firmware version showing on Beadatools?
tuftybruno
Post by tuftybruno » Thu Nov 13, 2025 12:18 pm
It shows 7.10 after flashing. I am able to upgrade to 7.18 but still notes as model 5 (sent in previous screenshot).
Not sure if relevant, in win11 device manager the device Hardware Ids are:
USB\VID_4E58&PID_1001&REV_0718
Based on quick research I believe the NXElec is suppose to be: VID_1FFB
Beada 710.png (11.14 KiB) Viewed 29488 times
Post by esky-sh » Thu Nov 13, 2025 4:41 pm
Looks like your environment was polluted seriously by some mis-operations and a normal reset can not recover it. We will provide a whole eMMC image to let you rewrite the device. Will let you know soon.
tuftybruno
Post by tuftybruno » Fri Nov 14, 2025 6:39 am
Thank you!!! Look forward to getting this fixed.
Post by esky-sh » Sat Nov 15, 2025 5:01 pm
You can force control board to USB memory stick mode and write the image file to it.
https://www.elinux.org/INNOSTICK6#First_time_Power_On
