neoscope
Post
by neoscope » Mon Dec 16, 2024 6:30 pm
esky-sh wrote: ↑Mon Dec 16, 2024 5:36 pm
So you had manually adjusted partition table on your TF card?
yes, I had. I following steps on your thread.
Just to confirm is the hardware ok although there is no blue led/lightning when I plug in the cable? the monitor itself have a backlight.
Post
by esky-sh » Mon Dec 16, 2024 6:45 pm
When you have solved (or confirmed that do not have) this partition overflow issue. Then we can move on to the next steps to address this black screen issue:
1. Restore ext4 partitions
You can follow this thread to restore content of 2 ext4 partitions on your TF card.
https://esky-sh.com/bbs/viewtopic.php?f ... t=10#p3597
2. Copy files on FAT16 partition
You can find 2 firmware files(winter-5c.dtb and zImage) on same google drive and copy these 2 files to FAT16 partition. If Windows report this FAT16 partition got corrupted then you can format it again before copy.
neoscope
Post
by neoscope » Mon Dec 16, 2024 7:33 pm
esky-sh wrote: ↑Mon Dec 16, 2024 6:45 pm
When you have solved (or confirmed that do not have) this partition overflow issue. Then we can move jon to the next steps to address this black screen issue:
hi I am sorry, want I want to restore the `.pmf` from the google drive that you PM, somehow all the partition erased, can you help me to restore them first?
- for esky-sh.png (124.85 KiB) Viewed 107750 times
neoscope
Post
by neoscope » Mon Dec 16, 2024 9:30 pm
Yes I know, but I think I somehow mis click or choose something wrong this time. I am a bit distracted earlier this morning when I try to restore the image.
Friend, can you help me to create the partition again?
Post
by esky-sh » Tue Dec 17, 2024 12:11 am
As far as I remember you had created a disk image for backup in early August. You can recover your TF card with this image as a fundamental base.
neoscope
Post
by neoscope » Tue Dec 17, 2024 7:13 am
esky-sh wrote: ↑Tue Dec 17, 2024 12:11 am
ok, I just check all my harddisk, and cant found it, and also the link where I share it to you is expired already. Is it possible for you and the team help create disk image so I can recover back my display?
admin
- Site Admin
Post
by admin » Tue Dec 17, 2024 6:03 pm
neoscope wrote: ↑Tue Dec 17, 2024 7:13 am
You can use GenericMassStorageClass(29GB).ptf to recover your partition table. This file is in the same folder on google drive.
neoscope
Post
by neoscope » Tue Dec 17, 2024 10:25 pm
admin wrote: ↑Tue Dec 17, 2024 6:03 pm
Hi friend,
I already recover my partition table by using
and I restore using the image file in google drive link that sent to me on August.
Now I found out the devices detected as Unknown Device and the backlight not turned on at all.
Post
by esky-sh » Tue Dec 17, 2024 11:15 pm
please open your Windows device manger and take a screenshot of this 'unknown device'
