Post by esky-sh » Wed Nov 30, 2011 9:21 am
dezso
Post by dezso » Wed Nov 30, 2011 8:18 pm
Is this nk.bin on the ftp?
Can you/would you share the BSP for this?
Post by esky-sh » Thu Dec 01, 2011 2:24 am
nk.bin and SDK will be upload to ftp in this week.
We are considering provide this BSP source code to customers whom purchased our frame. But we need a bit time for decision.
dezso
Post by dezso » Fri Dec 02, 2011 11:13 am
Cant wait for it!
Thanks for all your hard work...
Post by esky-sh » Sun Dec 04, 2011 10:16 am
The image files is uploaded to FTP now. :)
You may need to expand boot partition of your TF card to 120MB in order to contain a NK.bin image larger than 70MB.
Here is a tutorials link for how to do that -->
http://code.google.com/p/beagleboard/wi ... DiskFormat
P.S. the backlight control included in this version.
dezso
Post by dezso » Fri Dec 30, 2011 5:32 pm
Finally got some time to play with that image.
Works great, a few note, Ethernet not included ? how is that ?
All setting are non persistent, isn't it possible to use sd card to retain user setting ?
How we doing on the decision about releasing the bsp so I can attempt to customize it bit !? Hope there will be a favorable decision made soon.
Its really hard to work with it like this.
Thanks for everything tho.
Happy New Year for all. :arrow: :idea:
Post by esky-sh » Fri Dec 30, 2011 7:51 pm
dezso wrote:Finally got some time to play with that image.
Ethernet driver already included in this image. Do you have problem to work with it?
BTW, the system hive will not be saved when power cycle the board. We may resident it to SD card in next version.
Happy New Year! :)
dezso
Post by dezso » Sat Dec 31, 2011 11:29 am
Cant get the Ethernet port to work, under network all I'm have is USB Serial :(
Also no link lights are on the router or the board itself.
Post by esky-sh » Sat Dec 31, 2011 7:30 pm
What your BB revsion is? Had you verified ethernet hardware before?
dezso
Post by dezso » Sun Jan 01, 2012 12:25 pm
nk.bin file info 77.3 MB (81,068,739 bytes)
BSP version 2.00.00.02
