Flash NOR with JTAG Problem
kebrzyk
Post by kebrzyk » Fri Feb 19, 2010 1:01 am
I have a problem, because when I want re-load supervivi I got
Error: Can't download driver to speciefied address
My flash is is SST39VF1601.
I set:
16-Bit x 1-Chip
Flash start address: 0
RAM start address: 3 000 000 000
Everytime when I want "check" in H-flasher I get this error.
Is possible that NOR is broken?
please help me
Re: Flash NOR with JTAG Problem
Post by nicolas » Fri Feb 19, 2010 11:23 am
Did you follow these instructions viewtopic.php?f=6&t=45 ?
Once you setup H-JTAG properly, it should work.
If you can boot from the NOR, then its not "broken"
kebrzyk
Post by kebrzyk » Fri Feb 19, 2010 12:04 pm
yes I did exactly like in this instructions.
I can't because probably I erased NOR accidentally when I first time tried change supervivi.
Now H-flasher doesn't see my NOR.
It's look like that:
h-jtag 1.JPG (62.74 KiB) Viewed 5109 times
And when I press 'Check':
h-jtag Check.JPG (34.93 KiB) Viewed 5065 times
Post by nicolas » Fri Feb 19, 2010 2:17 pm
The error tells it all. The flash selected is not the flash on your mainboard.
kebrzyk
Post by kebrzyk » Sat Feb 20, 2010 12:12 am
I think that it is my flash.
