tq6410 software update(20110319)
Post by esky-sh » Thu May 05, 2011 12:28 am
2011-3-19 Windows CE 6.0 update
- add S3C6410 MFC based TCPMP player
- add USB WiFi PnP support
- MAC address set utility
- CMOS Camera test utility
- modify timming for AT070TN92 LCD
dezso
Re: tq6410 software update(20110319)
Post by dezso » Mon May 23, 2011 10:00 am
Hello
I really need you guys to fix the WinCE6 BSP.
The backlite constantly ON !!
Will not turn off no mater what is the settings set to.
Is it registry ? IO port setting? OS build? what ever is it please look in to it and fix it.
dezso:
dezso
Post by dezso » Fri Jun 03, 2011 2:40 pm
Anything ?????
dezso
Post by dezso » Fri Apr 27, 2012 6:45 pm
The os image build from this bsp not working.
Today I decided to make a new os image, copied fresh from the fpt, build with no error, but the WINCE does not start.
It will load " WinCE 6.0 nboot for tq6410 Reading...Launch Windows CE..." after this nothing, windows pc comes up with USB device not recognized !
Is there anything need to be changed before sysgen ?
Nothing was changed in the Catalog or any file, option.h set up for #define LCD_A70.
The reason for making new os because my touch cannot be calibrated !
I can go thru the calibration steps but after selecting the 5th point it will just goes back to start from the beginning.
The image found in the ftp boots and working but no luck to calibrate touch screen..
Again nothing was changed on the board, it was in anti-static bag for moths, wasn't really using touch screen in the past since I was working with mouse.
Need some help here ASAP, help...
dezso
Post by dezso » Fri Apr 27, 2012 8:12 pm
I figure that much the my digitizer is bad, the lower right section is completely unresponsive.
Made a simple app to draw on the screen following the mouse, since the calibration data in inaccurate most of the screen has a 3/4" offset but the lower right corner not sensing anything.
esky I see you are selling this 120899440457 in ebay for 2440/6410, I thing I got one of this from you for the Beagleboard but it's not work at all with the 6410 !
dezso
Post by dezso » Thu Sep 20, 2012 7:19 pm
dezso wrote:Hello
dezso:
I might just find a place for this board finally, but I really need you "Please" to figure out how to tun off the back-lite, WinCE has absolutely no control over it.
Don't care about changing brightness "would be nice", just want to turn it off after 10 minute...
dezso
Post by dezso » Mon Sep 24, 2012 4:50 pm
Anyone could help to modify the bsp listed in FTP so the backlight time-out in ce6 will turn the LCD backlight off.
dezso
Post by dezso » Sat Oct 06, 2012 10:49 am
Now its really upsetting that you completely ignore it, this function had not worked from the beginning.
It just another way to say "Thank you for buying my product instead of FriendlyARM MINI6410"
