I have problem with bed blocks
dgin
Post by dgin » Sun Oct 24, 2010 4:45 am
Hi, I have many bed blocks in to nand flash.
When I press "f" or "nand scrub" for formating nand flash, I have message:
Enter your Selection:f
NAND scrub: device 0 whole chip
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
When I press "y", I have message:
scrub aborted
What I have to do?
Re: I have problem with bed blocks
Post by esky-sh » Tue Oct 26, 2010 5:48 am
what is your boot mode for u-boot? nor boot or nand boot?
dgin
Post by dgin » Thu Oct 28, 2010 3:14 am
I understood. For formatting nand flash, after pressure "y" I had to press "enter"
