I have compiled a 64bit version of the secbulk.sys USB driver and it is working fine with DNW on Windows XP X64. I can upload it if anybody wants it, but be warned that it is not Authenticode signed, so the only 64bit OS it will work on without extra tricks is XP X64.
P
64bit USB driver for DNW, etc
Re: 64bit USB driver for DNW, etc
Thanks and please, I need to update my rom under win 7 64 bit computer but it just stuck at this files....
(looking around a 32 bit computer is a trouble for me...)
Here. Unzip contents into a dir somewhere you will keep. Run install.bat to install and remove.bat to uninstall. You did read the part about only working on XP X64, yes?. It will only work on Win7 64 if you use the hack to turn off driver signing check.
This may help you :
P
This may help you :
Driver signature enforcemente overrider 1.3b
Steps :
download this soft and install
http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=34
Select "enable test mode" -> next -> ok
Select "sign a system file" -> next -> location of secbulk.sys, for example : "c:\downloads\inf64\secbulk.sys""
Install secbulk:
Click Right button "install.bat" -> run administrator -> wait install hardware
reboot Pc
P
- secbulk64.zip
- 64bit USB driver for DNW
- (46.5 KiB) Downloaded 2983 times
thanks a lot!!!
but however every time I try to start to flash the machine, the machine just start and on its own and burntool just :
[SUCCESS: ReadFile otgtype:(1) hRead:(0x3b0)]
[SUCCESS: CreateFile]
[Memory Allocation! txBuf = 0x5080048 ]
[UsbTxFile start! run_addr=0xffffffff]
[UsbTxFile end]
Find Device From Name
Opened successfully.
Can't Readfile otg type.
[ERR: open_file read file(-1)]
[UsbTxFile end]
If it's getting that far, I don't think it is a USB driver problem. You could try the same operation with Microsoft's Virtual Windows XP 32bit which is detailed in another thread near here, and see if you get different results. You could also install and run DebugView (was SysInternals, now MS). The USB driver is a debug build and will send messages (including error messages) to the DebugView window.
http://download.sysinternals.com/Files/DebugView.zip
Anybody know what "Can't Readfile otg type." means ?
P
P
