How to run the Non OS sample code on power on? Presently it has to be run through bootloader menu "Download & Run", which I do not want to do. I want to get it automatically executed on power on.
Thanks in advance.
Running Non Os Sample code on Power On
kemalony76
Re: Running Non Os Sample code on Power On
thats what I want to have, still no answer found.khire_s wrote:How to run the Non OS sample code on power on? Presently it has to be run through bootloader menu "Download & Run", which I do not want to do. I want to get it automatically executed on power on.
Thanks in advance.
I was searching for this for some time! The answer is so easy....
Some names in the vivi menu are simply idiotic. To upload your non-os file to nand (e.g. mini2440test) you simply press a for "absolute user application", upload your file, switch to NAND and restart. done
