Hyperterminal setup
dprotas
Hyperterminal setup
Post by dprotas » Fri Oct 02, 2009 4:10 pm
I need to know the parameters for the connection via Hyperterminal with a MINI2440. So far I'm able to get some output, forcing 7-bit ASCII and ANSIW emulation, but the text is still garbled.
This is my current setup, and how the text is garbled:
Any pointers will be really appreciated!
Thanks in advance,
Diego
Re: Hyperterminal setup
Post by nicolas » Fri Oct 02, 2009 5:04 pm
I know this may not answer your question directly, but have you tried using the DNW utility ?
Its like a terminal program, but also handles uploading of files and such for the supervivi bootloader.
dprotas
Post by dprotas » Sun Oct 04, 2009 6:36 pm
Thanks, I'll try that on Monday.
slowbuys
Post by slowbuys » Tue Oct 20, 2009 2:44 pm
Set Hypterminal on PC to 115200 Baudrate and no hardware flow control.
Page 32 in the manual.
