ftp://s3c2440/mini20090825/
Current version can run on 128MB nand flash mini2440+ TPO 3.5" LCD Screen.
You can try to install this image on your board just like linux but you may need to locate file system image to SD Card if your board has only 64MB nand flash. This will require a boot command line change.
See pictures-->
http://cgi.ebay.com/mini2440-S3C2440-AR ... m332.l1262
Google Android on mini2440
