Assume USB Disk is in FAT32
Following messages will appear after USB Disk plug in:
SCSI device sda: 2000561 512-byte hdwr sectors (1024 MB)
sda: Write Protect is off
sda: assuming drive cache: write through
/dev/scsi/host2/bus0/target0/lun0:<7>usb-storage: queuecommand called
unknown partition table
Attached scsi removable disk sda at scsi2, channel 0, id 0, lun 0
Mount device:
[root@FriendlyARM /]#mount /dev/scsi/host2/bus0/target0/lun0/part1 /mnt
Check files on disk:
① [root@FriendlyARM /]#cd mnt ② [root@FriendlyARM /]#ls
How to mount USB Mass Storage Device under Linux
forumuseridrohit
Re: How to mount USB Mass Storage Device under Linux
I am newbie and have just started learning linux on Mini2440. I am able to access my SDcard but while accessing usb I am facing problems.
I get the following messages on hyperterm when I plugin my usb memstick.
This is mentioned in the document as well.... till now its fine. But I am unable to see the directory "udisk" as mentioned in the document.
Am I missing the procedure ?? plz help. I am unable to access the content of the usb drive.
Regards
Rohit
[root@FriendlyARM /dev]# usb 1-1: new full speed USB device using s3c2410-ohci a
nd address 3
usb 1-1: New USB device found, idVendor=058f, idProduct=6387
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Mass Storage Device
usb 1-1: Manufacturer: JetFlash
usb 1-1: SerialNumber: CF6I6M5L
usb 1-1: configuration #1 chosen from 1 choice
scsi1 : SCSI emulation for USB Mass Storage devices
scsi 1:0:0:0: Direct-Access JetFlash TS2GJFV30 8.07 PQ: 0 ANSI: 2
sd 1:0:0:0: [sda] 4014078 512-byte hardware sectors: (2.05 GB/1.91 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Assuming drive cache: write through
sda:
sd 1:0:0:0: [sda] Attached SCSI removable disk
Regards
Rohit
