Help with BeadaPanel 6P
sardonumsei
Contact:
Re: Help with BeadaPanel 6P
Post by sardonumsei » Thu Oct 23, 2025 7:24 pm
if you mean after I go to https://www.nxelec.com/service/beadatools/, no it continues to flash/
Post by esky-sh » Thu Oct 23, 2025 7:30 pm
That means rootfs not fully installed. Could you write rootfs file to both ext4 partitions via DiskGenius?
sardonumsei
Contact:
Post by sardonumsei » Thu Oct 23, 2025 7:34 pm
How do I do that? I do not see it in the guide.
Post by esky-sh » Thu Oct 23, 2025 7:40 pm
It is in Section 4 of this guide.
https://www.esky-sh.com/bbs/viewtopic.php?f=30&t=955
sardonumsei
Contact:
Post by sardonumsei » Thu Oct 23, 2025 7:48 pm
I did that each time I followed the guide and I just did it an additional time. Nothing has changed. It still does not respond.
Post by esky-sh » Thu Oct 23, 2025 7:57 pm
There are 2 ext4 partitions on the eMMC, had you been writing the pmf file to both 2 patitions?
sardonumsei
Contact:
Post by sardonumsei » Thu Oct 23, 2025 8:03 pm
No, just to primary(1). My device shows Primary(1) and Primary(2). The example shows Primary(1) and Unformatted(2). My device has 4 partitions Removable Disk J: FAT 16, Primary(1) Ext4 (Active), Primary (2) Ext 4, and Removable Disk K: Fat 32.
Post by esky-sh » Thu Oct 23, 2025 8:18 pm
You can write the pmf file to both of Primary(1) Ext4 (Active) and Primary (2) Ext 4 partitions via DiskGenius.
sardonumsei
Contact:
Post by sardonumsei » Thu Oct 23, 2025 8:39 pm
That worked. I can now access the panel. There are still some issues but I will make sure they are not Windows related.
sardonumsei
Contact:
Post by sardonumsei » Tue Oct 28, 2025 5:17 pm
BeadaTools identifies the panel as BeadaPanel 1280x480. I connect and hit test screen. It has a button for model 6 test. However the test does nothing. Time Sync seems to work. Play a media file does nothing as well. When I run Aida64, which used to work fine, I get the attached display. I have also attached what the display should look like for reference.
Screenshot 2025-10-28 201624.jpg (404.59 KiB) Viewed 14967 times
Screenshot 2025-10-28 201624.jpg (404.59 KiB) Viewed 14968 times
Screenshot 2025-10-28 201624.jpg (404.59 KiB) Viewed 14969 times
beadapanel disply.jpg (446.82 KiB) Viewed 14969 times
