igo 8 running on qq2440
Delavar
Post by Delavar » Tue Apr 28, 2009 1:09 pm
Here is picture of igo 8 running on qq2440 and bluetooth GPS connected to it
http://crazy-embedder.blogspot.com/2009 ... works.html
Re: igo 8 running on qq2440
Post by esky-sh » Tue Apr 28, 2009 7:11 pm
This is really cool! I had never seen a GPS can run under 800x480 resolution before. Could you give us more info for igo 8?
Delavar
Post by Delavar » Wed Apr 29, 2009 12:17 am
Igo 8 is on SD card. You need to change SYS.TXT
[interface]
resolution_dir="800_480"
vga=0
[rawdisplay]
highres=0
screen_x=800
screen_y=480
I need to test it in real car.
krasimirr
Post by krasimirr » Wed Apr 29, 2009 11:38 am
How about the BT dongle support? Is it included in the image or you have built new CE image with additional components?
Delavar
Post by Delavar » Wed Apr 29, 2009 11:50 am
USB BT support is included in platform. You need to leave only USB driver and delete other BT drivers. I will post the details later, when I finish.
Delavar
Post by Delavar » Wed Apr 29, 2009 1:35 pm
krasimirr
Post by krasimirr » Thu Apr 30, 2009 2:20 am
Thank you!
krasimirr
Post by krasimirr » Sat May 02, 2009 6:21 am
What kind of a BT dongle is yours?
I tried with a generic one with I.S.S.C 1002 chipset but when it is plugged, the OS asks for a driver name? Is there a need to place the VID and PID of the dongle somewhere in the registry?
krasimirr
Post by krasimirr » Sun May 03, 2009 6:20 am
Now it works with I.S.S.C dongle. Bluetooth discovery works.
Now I have to build a tool to perform this setup of virtual com port over bluetooth. There is a nice example in the msdn called "BTSquirt" http://msdn.microsoft.com/en-us/library/cc500412.aspx.
Is it possible to perform this setup with registry settings only?
Delavar
Post by Delavar » Sun May 03, 2009 10:40 am
I have used the printUI example from Windows CE samples. I'm still working on it. I'm changing it to something useful for GPS. I don't know if you can do it only from registry.
