Help with Windows 5.0 clock
My Windows clock does not work. It is stuck at June 2489, 12:07:09AM. How do I enable it in platform builder?
Re: Help with Windows 5.0 clock
Hi All,
I found a problem related to my previous one: Each time I try to set the date to a day past the 7th of any month in the Date/Time dialog box, the date is reset to 2489. Has anyone run into this problem as well?
Also, the system slows down to a grind from repeatedly calling GetLocalTime() when I attempt the above.
FYI,
I found and fixed a bug in OEMSet/GetRealTime() in the kernel.
Could you give us more details for the bug? and what the release version is?
nice find itouch...submit it to MS for $$$
