How to make jffs2
mgrunt
How to make jffs2
Post by mgrunt » Tue Nov 03, 2009 12:09 pm
Hi all, i install to my mini2440 (128MB NAND) u-boot, and kernel. Both works OK. Now i must make root filesystem. It's possible make from file directory structure (/bin, /usr etc.) JFFS2 file? Probebly yes, with make.jffs2 program. But program have several parameters, and i don't know, which values i must set for NAND 128MB. Can you enybody help me?
Thank you
Michal Grunt
mgalemin
Re: How to make jffs2
Post by mgalemin » Tue Nov 03, 2009 12:29 pm
Hi Michal,
Try to use buildroot. It is an extremely useful stuff.
Untar it and execute 'make menuconfig'. Change next parameters:
Target Architecture
    [*] arm
Target Architecture Variant
    [*] arm920t
Target ABI:
    [*] EABI
Toolchain
    [*] Enable RPC // need for NFS support in busybox
    [*] Use software floating point // need for for busybox
    [*] Build/install c++ compiler and libstdc++? // need for QT compiling
Package Selection for the target
    [*] <choose software you want to use in your system>
Target filesystem options
    [ ] ext2
    [*] jffs2
        Flash Type
            (x) NAND flash with 2kB Page and 128 kB erasesize
Save these settings and execute 'make'. You'll find ready to flash rootfs.arm.jffs2 rootfs image in ./binaries/uclibc/ folder. Buildroot will download and build all necessary packages (toolchain, binutils, uclibc, busybox etc.)
Enjoy. :)
tull
Post by tull » Sat Nov 07, 2009 10:23 am
Hello, can you please advise how to set up packages in buildroot I had properly configured Xserver and QT?
