again, you are not installing the lcd anything.
You need to properly setup PB.
Once you stup the files, it will build fully and include the lcd stuff.
I was checking over the manual and that specific version doesnt have the PB information, sorry.
There is a thread here:
viewtopic.php?f=15&t=12&p=16&hilit=pbxml#p16
(You dont have to follow the Build SDK section)
There is also this PDF
http://www.developmentboard.net/ressour ... opment.pdf
1 important thing, make sure you have adjusted the defines for the lcd you are using.
(/inc/options.h)
