how many hours Supervivi flash info takes on your mini2440?
ekilab
Post by ekilab » Fri Aug 07, 2009 5:44 pm
Hi I have now waited for 3 hours for the mini2440 utility supervivi
flash info command.
I have miserably failed to find any documentation to the supervivi flash info
one discussion in the web does side the subject, but my chinese is so poor, that I dont understand it.
http://blog.chinaunix.net/u2/78300/showart_1274577.html
at least there is some s3c2440 specific in the code of the blog:
case TYPE_S3C2440:
chip->IO_ADDR_W = regs + S3C2440_NFDATA;
info->sel_reg = regs + S3C2440_NFCONT;
info->sel_bit = S3C2440_NFCONT_nFCE;
chip->cmd_ctrl = s3c2440_nand_hwcontrol;
chip->dev_ready = s3c2440_nand_devready;
break;
but as subject says:
could you tell me how long it takes to get the flash info from supervivi on your board.
Farawaybay lab run by Eki
the_fbi
Re: how many hours Supervivi flash info takes on your mini2440?
Post by the_fbi » Sat Aug 08, 2009 3:47 am
Is there any reason you're not using the H-JTAG application from the DVD and the Parallel JTAG adaptor?
Works fine under Windows (takes about 1 minute) and under Linux using sjf2440 (takes a few minutes).
ekilab
Post by ekilab » Sat Aug 08, 2009 4:32 am
the_fbi wrote:Is there any reason you're not using the H-JTAG application from the DVD and the Parallel JTAG adaptor?
lack of lpt (parallel printer) port in the PC is the reason not to use it.
the_fbi
Post by the_fbi » Sat Aug 08, 2009 4:40 am
Thats a bit of a pain :( Luckily my laptop docking station has one.
Anything in this thread which helps? http://www.friendlyarm.net/forum/topic/40
