UART 3.3V or 5.0V?
pilamaster
UART 3.3V or 5.0V?
After discovering documentation i came to the conclusion that UART(CON1 and CON2 on mini2440 board) working levels are +-3.3V. Is it right?
Re: UART 3.3V or 5.0V?
The uart's coming from the S3C2440 are 3.3v
The physicalserial port header on the mini24440 goes thru a level shifter (max232) which is +-12v.
pilamaster
I know that physical port header works through level converter. I want to connect BT-device which works with +-3.3V TTL directly to UART, you confirm my conclusion, thanks a lot.
