WEC7 BSP Serial Port Does not Work !!
Re: WEC7 BSP Serial Port Does not Work !!
Post by esky-sh » Sat Mar 09, 2013 5:00 am
In eboot stage, there is a command to active serial console output. You can paste your serial output here.
Post by esky-sh » Sun Mar 10, 2013 5:46 am
1. Did you load all these image files under BBone20120522/images/wince/retail_uart1/?
2. How do you set your serial port parameter on your PC?
3. What kind of serial cable you used? cross or not cross?
4. Can you observe any serial pulse on UART port?
Post by esky-sh » Sun Mar 10, 2013 7:33 am
yes. please use non-cross cable.
