7'' LCD not working on PandaBoard with Linaro 2.3.5
Re: 7'' LCD not working on PandaBoard with Linaro 2.3.5
could you please provide log when you type 'reboot' command?
we need more information to identify if it is really return issue, since we are not in the same city and the international post will cause extra long delay.
Here is the log.
Thank you.
Here is the log.
Thank you.
- Log - 20111223.zip
- (13.2 KiB) Downloaded 549 times
I had a look into your latest log and found the i2c write error disappeared after you reboot the software.
So the pwm backlight should work ok in this case.
Another mistake I found in your log
appearently you were not using boot.scr from our ftp, instead you were using default one from linaro 11.09 'official' release.
and linaro default boot.scr will boot system to hdmi display instead of dvi/lcd.
suggestions:
1. Please copy the boot.scr file from our ftp to your boot partition of sd card.
and power your board together with beada frame and do the same reboot cycle throught serial console. please attach log message as what you did in your previous thread, if the backlight still not work.
2. Please change R7/R8 from 4.7k to 6.8k on your NBD01 board.
this will help a lot for verify of i2c write error.
reading boot.scr
462 bytes read
Loaded script from boot.scr
Running bootscript from mmc0 ...and linaro default boot.scr will boot system to hdmi display instead of dvi/lcd.
suggestions:
Thank you for your last feedback, Android is booting now and the LCD works fine. I don't know why we had the wrong boot.scr on the SD card since I used your command present in the Android_Images_Installation_on_Pandaboard file and the boot.tar.bz2 was including the right boot.scr, so it is a mistery for me.
I did not have to type reboot to make it boot, nor to change the resistor.
We will order new LCDs soon!
I have a few questions: apart from the bootagrs in the boot.scr which is different from the Linaro version, how different is your Android version from the Linaro 11.09 ? It is possible to easily isolate the changes, build required drivers if any, and bring them in most recent Linaro releases like 11.11 ?
2 differences:fanchb wrote:Hello,
1. boot.scr
2. uImage
uImage file is binary of linux kernel. you may check with the source code for difference between linaro 11.09 and our customzied version. In a short word, we add 3 drivers into this linaro kernel: backlight, touchscreen and RTC.
Could you please let me know in which folder I can expect to find the right sources: Beada20111116 ?
Thank you!
Thank you!
Woud you mind to give us the exact number of the Linaro build you are using for Release 11.09 ? It will help us to look at code differences. So far we have been comparing source code between Beada20111116 and build 3.0-2011.09 of the Linaro distribution. We have found many modifications in Drivers\Input\mouse we were not expecting since you were only mentioning 3 drivers, not including the mouse driver.
Thank you!
Thank you!
1. Original linaro kernel source code is at here:
<project name="people/andygreen/repo-branch-archive" path="kernel" remote="linaro-other" revision="7840e5d9be030f239a5b40231a22a97bebad40b6"/>
2. Beada modified kernel source code:
/Beada20111107/Android/panda-linaro-android-3.0-kernel.tar.bz2
Users browsing this forum: No registered users and 22 guests
