Installing OS 'ANDROID'
Download bootloader...
Download bootloader succeed
Download kernel...
Download kernel failed
downloaded from ftp 2x, formated sd card and no luck, changed zImage_a70 for the new a70 in /tq6410-20110319/images/android, no change.
if i use some of the other friendly arm image found on the web, than that will install fine whoever it will exit with
Freeing init memory: 1396K
yaffs: dev is 32505858 name is "mtdblock2" rw
yaffs: passed flags ""
/init: line 103: can't open /r/dev/console: no such file
Kernel panic - not syncing: Attempted to kill init!
[<c016a9a4>] (unwind_backtrace+0x0/0xe4) from [<c04c31f8>] (panic+0x68/0x194)
[<c04c31f8>] (panic+0x68/0x194) from [<c01827e4>] (do_exit+0x68/0x664)
[<c01827e4>] (do_exit+0x68/0x664) from [<c018310c>] (do_group_exit+0xb0/0xe4)
[<c018310c>] (do_group_exit+0xb0/0xe4) from [<c0183150>] (sys_exit_group+0x10/0x18)
one_wire_status: 2
[<c0183150>] (sys_exit_group+0x10/0x18) from [<c0165e60>] (ret_fast_syscall+0x0/0x30)
Rebooting in 5 seconds..one_wire_status: 4
arch_reset: at
and there is nothing on the lcd...
why is this board different from mini6410 ?
tq6410 is designed by ?
every website i find with mini6410 have a board like this
my board is like this
not happy
