A S3C6410 board with smaller form factor
Post by esky-sh » Thu Mar 31, 2011 2:33 am
[Features]
CPU
- Samsung S3C6410A ARM1176JZF-S, Frequency @ 533Mhz
SDRAM
- 256MB Mobile DDR SDRAM
Flash
- 2GB Nand Flash
- 1MB Nor Flash, not mounted
LCD
- 4 wire resistive touch screen interface
- Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels
- Up to True Color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels
Interface and Resource
- 1 x 10/100M Ethernet RJ-45(DM9000)
- 4 x Serial Ports(1xRS232 w/ CTS&RTS, 2xRS232)
- 1 x USB Host
- 1 x USB 2.0 HS OTG, mini-USB AB
- 2 x SD Card Interface
- 1 x Stereo audio out, 1 x Micro In, 1 x Line In
- 1 x 20-Pin JTAG
- 4 x USER LEDs
- 8 x USER buttons
- 1 x PWM Beeper
- 1 x TV OUT
- 1 x SDIO Wi-Fi socket
- 1 x 20-Pin CMOS Camera Interface
- 1 x Battery for RTC
- 1 x Power In(5V), with switch and lamp
Expand Interface
- 2 x 20-Pin 2mm COM and Keypad
- 1 x 30-Pin 2mm SYSTEM BUS
- 1 x 50-Pin 2mm GPIO
Dimension
- 105 x 81(mm)
OS Support
- Linux 2.6.36
- Windows CE.Net 6.0(R3)
- Android 2.1
[Content List]
1 x S3C6410 board (Preload with Linux)
1 x Serial cable
1 x Net cable
1 x USB cable
1 x 5V power adapter
1 x DVD-ROM with product reference
[Pictures]
dezso
Re: A S3C6410 board with smaller form factor
Post by dezso » Thu Apr 28, 2011 9:43 pm
So witch one is the new board and witch one is the oldest board ?
Can I guess the one on the left is the oldest !?
