as I can use GPIO (I/O PORT) with CE 6.0. Does it exist some drivers?
Best regards
gpio to ce 6.0
barkakeops
pilamaster
Re: gpio to ce 6.0
GPIO driver for WinCE 6.0 with VB and C# examples
http://www.domodom.fr/spip/A-GPIO-drive ... ml?lang=en
cristianowa
Re: gpio to ce 6.0
I've used this image, it works everything fine,barkakeops wrote:http://www.thaieasyelec.com/Free-Servic ... orial.html
wince 6.0 image with gpio driver
PWM ( including TOUT1, that is not working in the BSP available in friendlyarm ),
ADC ( witch also is not working in friendlyarm ),
but I need the source code so I can tweak for my aplication,
does anyone have this ?
thanks in advice,
cristianowa
Re: gpio to ce 6.0
"Please tell me more detail .."Marat1982 wrote:Пожалуйста, расскажите поподробнее..
I'm searching for the source code for the Mini2440 drivers for winCE 6.0,
I've checked the BSP and the drivers I've found, are, mostly, incomplete,
the PWM driver has only the first channel (tout0 ) implemented,
the ADC driver is not implemented and GPIO also
( but Domodom has a tutorial in his site :
the CMOS camera (OV6950) also has only a small resolution ( 240 x 180 )
I don't want to reimplement the drivers from zero knowing that someone already did it,
so I would like to ask for this source code,
thanks !
best regards !
Cristiano
